New member Username: AirbornflghtPost Number: 3 Registered: Jul-05 | Ok, my dad has been looking for a cartridge to his Pioneer Deck for a while and hasnt been able to find one. When he bought it, he payed $50 for a M15 cartridge. I'm trying to find a replacement cartridge for the deck. Are these cartridges, or a replacement for them, still made? the best that we found is a radioshack piece of junk that has no volume. I'd really appreciate it for a reply and maybe a few site that are good sources. |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 7243 Registered: May-04 | To my knowledge the M15 is no longer available. There's no need to replace the cartridge with an identical model; there may be no need to replace a cartridge if the stylus assembly is still available. http://www.needledoctor.com/ |
Silver Member Username: Ca_convertCardiffUK Post Number: 175 Registered: Jan-05 | You can also try these guys out, they are very helpful. http://www.needles-and-spins.co.uk/ |
New member Username: AirbornflghtPost Number: 4 Registered: Jul-05 | does anyone know what cartridge it takes though, if it takes that cartridge, which one i can buy a a replacement? the cartridge is shot, we tried a new stylus. although, im a bit fuzzy on this elderly technology. I just need the whole deal, needle, cartridge, whatever they are called, is that just a cartridge? doesnt the cartridge come with the stylus? |
Silver Member Username: Ca_convertCardiffUK Post Number: 186 Registered: Jan-05 | A cartridge is the name given to the complete unit which includes the stylus, certainly if you buy one from a dealer then this is what you will get. Moving Magnet cartidges usually have the facility to replace the stylus when worn, a moving coil cartridge usually does not. Why dont you contact a local dealer for advice, this is what the hi fi shops are for. You could probably take your deck to them and they will fit and set it up for you aswell. |
New member Username: AirbornflghtPost Number: 5 Registered: Jul-05 | we dont have one, our town is a little rinky dink one, about 48,000 people. the closest thing we have is radioshack and we bought a cartidge from them and there is no volume to it now, it sucks, of course it does, its from radioshack. I emailed ortifon so i will see what they say. |
New member Username: TweakerttweakerPost Number: 3 Registered: Aug-05 | Try these they should have what you need I think. http://www.needledoctor.com/s.nl/sc.2/category.378/.f;jsessionid=ac112b1f1f43af2cb395dd2140d0b2ee8167c464f6ca.e3eTaxiNaN0Te38SaxqMaxa Ray1ynknvrkLOlQzNp65In0 http://www.speakerbits.com/Default.aspx?cat=22&menu=12 http://www.adelcom.net/OrtofonStylus1.htm http://www.musonic.co.uk/erol.html#7431x0&&http%3A%252F%252Fwww.google.com%252Fs earch%3Fq%3DOrtofon+M15E%26hl%3Den%26lr%3D%26start%3D10%26sa%3DN http://www.turntableneedles.com/index.asp?PageAction=VIEWPROD&ProdID=9339 http://www.export-japan.com/marketing/stylus/product_info.php?cPath=12&products_ id=727&osCsid=86bf2fe3f8a8450e1d14f694b713acbc http://www.vinylengine.com/phpBB2/index.php I hope one of these might help you.... Tweaker. |
Anonymous | Do you have the turntable plugged into a phono input on the receiver/amplifier. If you do not have a phono pre-amp, that may be the cause of your "no volume" problem. |
