Bronze Member Username: MisoSlovakia Post Number: 73 Registered: Feb-05 | I have denon 2800 and b@w 805s, is it possible to bi-amp these speakers? Reciever is able to play speakers A and B simultaneously,thanks for any help... |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 7236 Registered: May-04 | A-B speaker sets are wired in parallel internally in Denon receivers. You can use this fact to set up a bi-wire hook up but this will not be bi-amping since the speakers are still driven from only one amplifier per channel. |
Bronze Member Username: MisoSlovakia Post Number: 74 Registered: Feb-05 | thanks Jan, is it bi-wire any good? |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 7240 Registered: May-04 | http://sound.westhost.com/bi-amp.htm |
