Best centre speaker??
xclasov
Just bought a pair of TDL KV1s for my front surrounds, anyone suggest a suitable match sonically for centre speaker?
Username: Dakulis
Spokane, Washington United States
Post Number: 773
A TDL center with the same or very similar components if you're trying to timbre match or another TDL KVI used as the centre.
Otherwise, you're unlikely to get a true timbre match with another manufacturer's center.
