and then some more expensive models (for about 100-300€):
-Arcam A65 -Denon PMA-1500AE -Rotel RA-03
I also don't know which speakers would match that system. I've been looking at Monitor Audio Silver and Bronze series, JMLab Chorus, Acoustic Research, Energy C-3, Athena AS-B2. I would definetly go for a bookshelf speaker, because of the size of the room.
I'd like quite a strong bass, though i don't expect anything very powerful, but it should be decent. I prefer clean sound, a little warm (that's why i don't like NAD's sound, so NAD isn't an option).
i know they aren't warm, that they are clean, but i had DALI speakers on them and they really sounded very nice. Meanwhile NAD sounded very thumpy, i don't know how to say, but it wasn't precise. I mainly want to know, if it is worth spending more money, because Rega Brio played really nice.
i said, that i want a clean amp, not warm, i will add that "little warm" feeling with speakers, though i don't care if whole system will be clean, because this is a budget Hi-Fi.
Most likely i will go for Rega Brio and Energy C-3 speakers.
I just want to know, if brio will be short on power, because it has only 38W, the same is with RA-02 (40W). Is Azur much stronger (60W)?
The Rega Brio comes across with more authority than you'd expect for its 38watts. In fact, it seems more powerful than that. The strange thing is that when you play the Rega with the same speakers as another more powerfully rated amplifier, you tend to find you end up putting the volume knob in about the same place to get the same volume.
I have checked the specs of the Energy speakers and they are very easy to drive indeed (92db/8-ohm) so the Rega will have no problem doing them justice. I've used a Brio to drive Dynaudio Audience 42s which are much more difficult to drive (87db/4-ohm) quite happily, so power is not an issue here.
Yep very good match,although the Rega is stunning at that price and it would be hard for me to pass up at that price,but B&W and Rotel make a good combo,hey their distributor thinks so to,thats why they are distributed from the same firm in the states and Canada.
