Wiring bare wires into a jack
Username: Reverendaxlrose
SLiema, None Malta
Hi,
I had a samsung home theatre, the ht-dm150 and due to some problems I had to throw away the dvd player. So now Im left with the speakers and was wondering whether i could connect these to my PC. The speaker connections are the bare '+' and '-' wires and the PC connection is obviously through a jack. Is is so simple as buying a jack and wiring the bare wires into it? Thanks!
Username: Jan_b_vigne
Dallas, TX
Post Number: 7095
Probably not. You probably need powered speakers for your computer.
Username: Nuck
Parkhill, Ontario Canada
Post Number: 964
put the + into the middle, and the - onto the outside.
Stirred not shaken.
