New HK AVR435 ---- Big Problem
Username: Fnfast69
Will only stay powered on for about 10-15 seconds. tryed reset... same results with every thing hook up or not... ???
Username: John_s
Columbus, Ohio US
Post Number: 589
Jim, I had the same problem with my new AVR7300. At first, I thought I had a problem with the in-wall wiring to the surrounds. Turns out the wire was literally hanging by a thread on the suspended center channel speaker. I have since installed banana plugs on all speaker wires, both at the receiver and at the speakers.
My point is that you should check and re-check the speaker wiring, especially for possible shorts. Also you should be using no smaller than 16 gauge wire.
Username: Jan_b_vigne
Dallas, TX
Post Number: 7071
Disconnect all input and output cables and, with the "naked" receiver plugged into the wall, if the receiver will still only stay on for a few seconds, there is a problem. There could be a "auto on" function that you must click on/off to allow the receiver to stay on. Check your owner's manual and then give HK a call.
