Monster power
Username: Kdemirda
New York, NY USA
Post Number: 9
any body tried these monster power surge protectors and "current cleaners"? thoughts, comments...good product or waste of money...
Username: Riches1
Atlanta, GA US
Post Number: 196
Power Conditioners are a recommended component by audioholics.com. You should absolutely have your electronics hooked up to a surge protector at a minimum, so why not spend a few dollars more and get a surge protector/power conditioner combo.You can save a few dollars by getting the same thing by Tripplite, which you can find at partsexpress.com
Username: Bill984
Post Number: 98
i bought the 3500ht. figure if i'm hooking up 6000 worth of equipment may as well spend the 350.
Username: Artk
Albany, Oregon USA
Post Number: 2557
One of the few products by Monster that I recommend is their power conditioners.
Username: Kdemirda
New York, NY USA
Post Number: 10
thanks, I guess if you are going to spend the money on a pair of speakers and hear a difference on (I have a pair of Nautilus speakers)it will be well worth it...Happy New Year.
