New member Username: Want2noaudioPost Number: 1 Registered: Dec-05 | I have the Kef Q-7 and the matching center channel the Kef Q-9c with the Q-1 as the rears. My question is what sub to you lean towards in the 500- 1000 dollar range? I was considering the Kef PSW 2500 , Aperion Audio Intimus S-10, Outlaw LFM-1 or the Jamo D-4. Your advice would be helpful... Thanks |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 2552 Registered: Feb-05 | That Outlaw is a stellar buy and one of the first I would look at for HT at that price. |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 7060 Registered: May-04 | http://www.us.alegriaaudio.com/Tom%20Subwoofer.htm |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 7061 Registered: May-04 | http://home.comcast.net/~infinitelybaffled/page2IB-Gallery.html http://www.t-linespeakers.org/projects/steve/ |
Silver Member Username: Rysa4Post Number: 277 Registered: Jul-05 | Hey Jan- I dont think I can get that last one through the door!! |
New member Username: Want2noaudioPost Number: 2 Registered: Dec-05 | Thanks for the advice... The only thing with the the Outlaw is , it comes in any color as long as its black.. The wife wants dark apple or a medium cherry to go with rest of the equipment... Thanks. |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 3517 Registered: Mar-05 | The Hsu STF-3 is very similar to the Outlaw (designed by the same Dr. Hsu) and I think is available in other colors. hsuresearch.com |
New member Username: Want2noaudioPost Number: 3 Registered: Dec-05 | Thank you Edster for the advice... |
Gold Member Username: Edster922Abubala, Ababala The Occupation Post Number: 3520 Registered: Mar-05 | You're very welcome. Let us know what you choose and how you end up liking it. |
New member Username: Want2noaudioPost Number: 4 Registered: Dec-05 | I belive we are leaning towards the HSU- VT-F3 MK2 in a Rosewood finish.. Once again thanks for the advice... |
Silver Member Username: GavincummNew York USA Post Number: 458 Registered: Feb-05 | try this... http://www.norh.com/products/sub/index.html read up on it before you decide what to do. n0rh has a cult following in the audiophile community, and it is well deserved. Their subs come in marble and teak. To say they are beautiful is an understatement. Take a look at the teak sub on the pricing page. I have heard a pair of n0rh speakers, and found them very engaging, with a very inviting personality. If the subs are designed with the same passion, you won't be dissapointed. There is also an informative section in there describing how cheap sub amps create harmonics to trick the brain into thinking bass is actually being created, and what the n0rh sub will and won't do. It is a very informative website that will tell you how to find a great sub, even if you don't like what you find here, so PLEASE take a look. |
lafowtlowd Unregistered guest | BOSE, BABY!! |
goggly nuhhuh Unregistered guest | bose, baby!! |
New member Username: StevoMargate, FL. USA Post Number: 8 Registered: Apr-04 | SVS PC 20-39+ |
Bronze Member Username: DobyblueSt. Catharines, Ontario Canada Post Number: 27 Registered: Oct-05 | Give either the PW2200 or the Seismic 12 a test from Paradigm. Unless money's no object or size then look at the Servo 15 from Paradigm. |
Silver Member Username: GmanMt. Pleasant, SC Post Number: 814 Registered: Dec-03 | I would go for the HSU VTF-3 MKII, the SVS PB12 Plus in cherry or rosewood @ $999, or the Onix UFW-12 with R-DES (includes parametric program for balancing 100 mhz and down) @ $1099. |
New member Username: Unreal_tUnited States Post Number: 2 Registered: Feb-06 | Id look into Polk Audio Subwoofers. They are really a great company to trust! |
