Niles 4ohm Home Audio Speakers
Username: Jeffn918
Milford, Michigan
I have a new house and the builder had 6 Niles 4 ohm speakers installed, in 3 different rooms (2 in each room). The problem that I am having is that my Receiver, JVC R-X110 is 100 watts and 8 - 16 ohms. My receiver does not work with the Niles speakers. Does anybody know what I need to do to get these speakers to work? Do I need a new Receiver or an Amplifier? If so, do you have any suggestions on make/model? Help would be greatly appreciated. Thank you!
Username: Jan_b_vigne
Dallas, TX
Post Number: 7046
You need impedance matching autoformers. You can buy them in either the speaker switch box or the volume controls.
http://www.inwallstore.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=i&Categ ory_Code=impedance
