Amp for PSB B25
Username: Nike
Have just got new PSB Image B25 bookshelf speakers for my Yamaha RX-V496 but it sounds too dull and not satisfying at all. I am using a philips dvd player as source. For a decent stereo sound, should I change the amp or the source? what gear would be better.
Username: Malco49
Baltimore, Maryland Usa
Post Number: 17
i have those same speakers. GREAT CHOICE
i have a cambridge AZUR 540A and think it sounds
great highly recommended.
good luck!
Username: Nike
thanks mitchell
I have seen lot of ppl from this forum are NAD fans...Would C320BEE be a option too.
Does the source matter...or i can pull for somedays with the philips dvd player before i buy a NAD or marantz cdp
Username: Malco49
Post Number: 18
i really dont know tons about audio.but i dont think you can go wrong with NAD or CAMBRIDGE.
however i do know you have smokin speakers.
good luck with your choice let us know what you decide.
check out the reviews on cambridge stuff.
Username: Nuck
Parkhill, Ontario Canada
Post Number: 881
Nike, Nad and Psb have had a longstanding partnership under the same company for quite a while.
Certainly not exclusive and the Cambridge is competant for these smaller speakers.
I do know from experience that Psb speakers are not smooth and steady as far as impedance, they can wander quite far from the stated nominal.
That said, your two choices should have no problems.
The next one in line would be Rotel but I cant figgur how your Yamaha would sound dull.
The CDP may be lacking, but how dull is the sound?
The speakers might, might be underpowered, but more power is a poor solution to the source.
Can you try other CDP's on a trial basis, like borrow a friends unit?
Interested to know how you make out.
Peace.
Username: Nuck
Post Number: 887
Nike and Mitchell, I looked a little further into the psb B25's, and yeah, I might need another pair of fronts for upstairs!
Where did you guys buy them?
Prices?
Username: Nike
Mitchell - tried connecting a Marantz CD6000SE, the sound improves but can't compare it with the one I auditioned the B25 with. (i am talking abt NAD52i CDP with 520BEE) Thats the reason i thought the amp to be the weak link.
Well, dull means i feel like there is one more grill on the speakers. (i listen to speakers without grills, still...)
Username: Nike
Hi All,
I got settled with a NAD 521i CDP and 320BEE Amp..quiet happy with my purchase.
Thanks to all who posted and all the help.
M. Albert
Could the source CD player have made THAT much of a difference?
Username: Stu_pitt
New York City, New York
Post Number: 886
Their should be a big difference between a Phillips DVD player and NAD dedicated cd player. However, the source player wasn't the only change to the system - he went from a Yamaha receiver and Phillips DVD player to a NAD integrated amp and CD player.
M. Albert
Sorry I didn't read that correctly the first time. Even still, I had no idea that the DVD/CD combo could be that lacking in sound quality, as compared to a straight CD player.
So, the PSB's are a pretty good bookshelf speaker for the money?
M. Albert
Username: Stu_pitt
Post Number: 888
At that price, they're my personal favorite. Then again I'm a little biased. I've owned a few different PSB's for the last 15 or so years.
All things being equal, very few DVD players can match the sound quality of a dedicated cd player.
