New member Username: PangsterPost Number: 1 Registered: Jun-05 | Hi i am new to this forum! My case is really strange and hope people will help me!! I never dropped my ipod mini and its still in brand new condition with the execption that sometimes i dont charge the battery and it will run dead (but thats good right?) So i tried to charge the ipod mini in my car then the apple picture came out and nothing happen, i can turn it on at all! Then i took it home and charge it, the apple sign never came up and when i pressed all the buttons nothing happened! MY ipod mini is dead!! I am so upset! Can anyone please help me?? Thank you so much! |
New member Username: HalbyParsippany, NJ Post Number: 7 Registered: Jun-05 | What happens when you attach it to your PC? |
New member Username: PangsterPost Number: 2 Registered: Jun-05 | Havent tried yet! Let me try just now ok! thanks for your reply |
New member Username: PangsterPost Number: 3 Registered: Jun-05 | Just plugged the ipod to my pc but still nothing came up!! Do you know why? Please help |
bent Unregistered guest | Hold down Menu and Play at the same time to Reset the ipod mini . .. . you need to reboot it |
Anonymous | i need some help with my ipod mini too... it turns on and everything but whenever I import the songs from my cds I go to drag them to my ipod folder but everything is gray and there is a little picture of a lock next to the bottom where it shows the amount of space i have left on the ipod |
bent Unregistered guest | To answer your question anonymous .. .. you need to go into the ipod options within itunes and click on the button that says manually update your ipod. . . . you probably have it set for itunes to automatically update your play list. By clicking on manually update you can trash and change your playlist as much as you want |
blink-babe- Unregistered guest | For the person at the top who's iPod won't turn on, Press and hold the middle button and the menu button for 10 seconds and then it should turn on (the apple sign will come up after 10 seconds then the main menu will come up). |
blink-babe- Unregistered guest | Hi, my computer recently broke and wouldn't turn on...this was after a thunder storm. The man fixing our computer said it will take hours to save all my songs on iTunes and he charges £45 per hour he spends working on it, so my dad told him just to save the file My Documents. I am worried that all my songs on my iPod will get lost when we get the computer back because some of the songs were sent to me, and some I have to say were illegally downloaded so they dont have any files to support them. When I plug my iPod into the computer I was wondering if all the songs on my iPod will go onto the computer or will I have to find a way to get them onto the computer again. I am really annoyed and worried because some of the illegally downloaded songs are quite important to me. Please help by telling me if they will go back on to the computer or if they will all be lost!!! |
Somebody SUMWHERE!!!!????!!!! Unregistered guest | Hi, my computer recently broke and wouldn't turn on...this was after a thunder storm. The man fixing our computer said it will take hours to save all my songs on iTunes and he charges £45 per hour he spends working on it, so my dad told him just to save the file "My Documents". I am worried that all my songs on my iPod will get lost when we get the computer back because some of the songs were sent to me, and some I have to say were illegally downloaded so they dont have any files to support them. When I plug my iPod into the computer I was wondering if all the songs on my iPod will go onto the computer or will I have to find a way to get them onto the computer again. I am really annoyed and worried because some of the illegally downloaded songs are quite important to me. Please help by telling me if they will go back on to the computer or if they will all be lost!!! And btw I am using my computer if you were wondering how I was using the internet if my computer was broken. |
kaleigh Unregistered guest | hey i have a question..k so my ipod is connected to the usb and e verything but my ipod won't appear inthe itunes screan therefore i can't put any songs onto my ipod how do i fix that |
blink-babe- Unregistered guest | Is your iPod connected to the USB thing at the front of the drive? |
bent Unregistered guest | blink-babe- http://www.engadget.com/entry/7166385640773718/ |
blink-babe- Unregistered guest | thx!!! :-) |
blink-babe- Unregistered guest | soz it just told me how to get songs off my iPod i want to know how i can get them back on to my computer. thanx for helpin tho. |
bent Unregistered guest | blink-babe- You want to know how you can get them back on to your computer? . .. . If you read the URL i gave you it tells you step by step how to rip the songs off the ipod hard drive and copy them onto your Computers hard drive. |
blink-babe- Unregistered guest | oh ok, soz im not that brainy when it comes to computers lol. it was all very "technical" for me soz soz. |
Anonymous | Hi, is there anyone out there who could help me? my problem is, that I had some trouble unplugging it from the computer, so I decided to do a restore. However, when I tried to the apple logo then appeared on the ipod and turned off. When I tried to turn it on, the apple logo came up, followed by a picture of a folder with an exclamation point. does anyone know what i should do?? thanks people |
Bent Unregistered guest | Are you connecting the ipod via firewire or usb ... . I had the same problem with an ipod via firewire and i found out that my firewire busses had fried the ipod. Check your buses and does the ipod show up on your desktop? if not it could be fried if you get it up on desktop try wiping it and reinstalling the firmware and reseting the ipod by holding Menu and the Center button on your scrollwheel till it resets. and remember Google is your friend - http://docs.info.apple.com/article.html?artnum=61003 |
Bent Unregistered guest | You may have also installed the wrong firmware |
Unregistered guest | hi anyone my ipod has locked up in the on mode.screen says 1of543 in left corner track 6 in middle 0:00 bottom left & -3.58 bottom right. any suggestions please |
Mallory Angel Unregistered guest | How do I get the songs on iTunes to my iPod Mini?? I am not a computer person, so say it in blonde-proof words. Thanksss. |
New member Username: Andrea14Yak townUnited States Post Number: 1 Registered: Jul-05 | Hey, my ipod mini frezzes some times for no reason. I have only had a mini for about 2 1/2 months and ive already had to bring it back and get a new one because it froze. Since then it has froze twice and ive had to wait for the battery to go dead and then recharge it can someone tell me why this is. |
Kylie Whilyyy21 Unregistered guest | Hi, my ipod mini freezes as well...it was pulled out of my hand by some idiot and fell on the top left corner of the ipod (if the screen is facing you). Now every once in a while whem i try to choose a song... my ipod temporarily stops and goes back to the main menu. the song will play if i select it again but this becomes quiet annoying...can anyone help me out, thanks. |
Bent Unregistered guest | Mallory Angel "aka Blondy" Plug in your Ipod via Firewire or Usb to your computer Your Ipod should then pop up in Itunes as well as your Desktop Open Preferences in Itunes, in preferences you will have the options General,Ipod,Podcasts,Audio, IMporting and so forth Click on Ipod then the window will open for ipod then click the button for Manually manage songs and playlists then hit OK Now go into your library window inside itunes where you have all the albums listing or songs depending on your library, then just drag and drop the music you want to the little ipod icon in your itunes Source window. and remember the thing called Google . .. http://www.ipodlounge.com/index.php/articles/comments/ask-ipodlounge-5-12-05/ |
Bent Unregistered guest | There are 3 ways of moving tunes to your ipod i explained one above it is my preference because my itunes lib is 80 gigs and that wont fit on a mini so i have to pick and choose what i am willing to listen to during a battery cycle. |
Bent Unregistered guest | http://www.apple.com/support/ipod/ |
tomcat335 Unregistered guest | hey I dont know how to tranfer playlists to my ipod mini! help, i am a total noob |
tomcat335 Unregistered guest | um nm i figured it out |
Jorge Miranda Unregistered guest | Mi ipod mini freezes sometimes since I updated with June 26th file. It has the same problem as the Kylie Whilyyy21's ipod, sometimes when you try to play a song, it freezes for a while and then either play next song or goes back to the previous menu. I haven't hit it since I bought it (january this year) and I'm pretty sure the problem appeared after last update. Can anybody help me? Cheers. |
Unregistered guest | My ipod froze and i don't know what to do. Please respond. |
Unregistered guest | Hey guys. I'm new to this. I'm really frustrated with my ipod because it won't show up in itunes, and the ipod updater won't recognize my ipod either.. so i can't update the software. we recently got a new hardrive in my computer so there would be more space. I started having this problem AFTER we got the new hardrive. Could there possibly be a relation?? I've seriously tried everything, i went to apple.com and did all the troubleshooting, including reinstalling itunes, and the ipod software. Also, my IpodService is in drive E, not drive C. I don't know why, but could there be a reason for that too? i've also formatted my ipod and erased everything on it, restoring it to the factory version. and still nothing. im so confused!! ![]() -teresa an email or a reply would be very helpful and greatly appreciated! ![]() |
aznangel1033 Unregistered guest | Apparently my iPod mini needs to be formatted, but it's taking forever. Is this supposed to happen? If not, how do I fix this problem? |
Jessica new Ipod user Unregistered guest | HI I was having trouble with my Ipod charging. When it is transferring songs, it appears to be charging, but when the transfer ends, the little lightning bolt goes away and it eventually turns off. I tried to reset it, as was mentioned above. Anyone else have this problem? |
jenn needs help Unregistered guest | i need help really bad. My ipod mini isnt working right. Actually, it works fine untill i want to put songs on it. When I plug it into my computer nothing happens. It doesnt charge untill i hold the play button down. It wont show up on itunes or my computer at all. |
maddy Unregistered guest | Hi... I need to know somethings BEFORE i buy my ipod mini...I was wondering if u could help me? First... does it come with a usp cord? And ear phones, or something to listen to it with? and the other thing was am i likely to need to return it? because im getting it from overseas... thanks alot for ur help! |
maddy Unregistered guest | http://www.apple.com/support/ipod/tutorial/ this shuld help alot of people with their problems.... just click through untill ur question comes up, and it shows a movie to help explain... good luck ![]() |
jasmine Unregistered guest | my jerk of a friend was plaing music quiz and when it said wrong the idiot hit menu no my ipod mini is frozen with a screen that says wrong and my score of the game i have it pluged in my pc but it has still been frozen for 1 week. what 2 do?plaesr help!!!! |
Unregistered guest | hi i had some songs downloaded on to my ipod but they have been deleted from i tunes but then when i was charging my i pod on the computer it wiped all the songs how do i retrieve the songs help please |
Bent Unregistered guest | Helpless http://www.engadget.com/entry/7166385640773718/ |
Anonymous | Help! I installed a version of iPod linux for my ipod mini (yes it was designed to work with the mini) but I unknowingly made a mistake (I forgot to specify which type of OS to use.) Now when I try to boot my iPod lots of text comes up after which the screen gets some fuzzy dots on it and the iPod mini becomes unresponsive. I have tried resetting (menu+center) but that just makes the same thing happen all over again (text, then crashes.) To make matters worse, my Windows PC will no longer recognize my ipod after installing iPodlinux; thus I cannot restore it to factory defaults. Is there any hope for my iPod Mini??? |
Jessiejellybeans Unregistered guest | i was trying to chrage my ipod mini and i plugged the plug into the socket then into my ipod mini but the lightning bolt doesnt appear and nothing happens i have tried changing the fuse but it makes no difference but the ipod still worked untill it totally ran out of battery so now its dead! what should i do?? |
jord Unregistered guest | I have a problem. when my sister's ipod plays music quiz ( even when it isn't multitasking it freezes up. help! |
Anonymous | help ive tried resetting my mini ipod and charging it up both via the computer and the socket even though it didnt need it but it still wont turn on! it comes up with the apple logo but then an exclamation mark nd a picture of the ipod with a sad face comes up-what does this mean? please help |
exolerated Unregistered guest | help!!!! i have an ipod mini and my sister has an ipod shuffle we have one computer in our house and my parents cant figure out how to fix the library so i can get explicet songs and my sister DOSNT get them downloaded automatically on to her ipod shuffle!!! i need help!!!! how can i do this so my sister dosnt get these songs onto her ipod!!! |
New member Username: GreeneyedgirlPost Number: 1 Registered: Aug-05 | Hello! Back to the default question for a minute please...I just got 334 awesome songs on my ipod mini, but my settings are still on default to erase everything except what i have on itunes, I am afraid that if I plug it in it will erase my good stuff before I have the chance to change the settings...any advice would be great! Thanks so much! |
Kelly564 Unregistered guest | HELP!!! I charged my ipod mini yesterday for like an hour and when i unplugged it was really hot but the real problem is it wont turn on at all |
Kelly564 Unregistered guest | People it would help alot if you answer my other question quickly cuz im going to exchange it today and i dont want to lose my songs!! |
debbie5864 Unregistered guest | Hello, My partner owns a mini ipod. only had it since march! I have a ibook G4 which is where his itunes is. One day the battery ran down on his ipod mini so he plugged it into the mains and an apple icon flashed up and then a folder icon which an exclamation mark! We let it charge and then plugged it into my ibook through the firewire port. the screen on ipod mini changed to do not disconnect as it would usually do. However it never appeared on the desktop or in itunes? had to physically just pull the wire out to disconnect it! I have tried to reset it but to no avail and i cant restore it as it doesn't appear on my desktop to do so! It is still under warranty so i thought i'd send it for service under that but someone told me that if they think iv'e done it its going to cost me around £150! i can get a new one for that! any ideas or thoughts on this??? |
Gold Member Username: Project6Post Number: 3313 Registered: Dec-03 | Try the techsupport at the apple website. They have a tutorial on how to check your iPod for the problems you are experiencing. |
Brandi Unregistered guest | Hi I just got this thing litterally hours ago, and it's working fine .I was just wondering how to erase songs from it. I have scowered the directions and they say nothing about deleting songs. Can anyone help me with my Ipod mini? |
Gold Member Username: Project6Post Number: 3341 Registered: Dec-03 | Go to iTunes. From here you should see a list of all the songs that you have. Uncheck the songs you want removed for your iPod. Dock your iPod, when the iPod syncs with your computer the songs you unchecked will be removed from your iPod. Check your manual again. Read more about iTunes and iPod by looking at the CD included with your iPod. Use the help and search function. Do you really expect not to find instructions on a player which whole purpose is to add and remove songs for listening? |
Brandi Unregistered guest | Thank you! I actually figured it out by myself when nobody wrote back yesterday, but I appreciate the help. |
jess mariano Unregistered guest | how do i turn my ipod off |
Unregistered guest | my ipod mini is charging off of my computer and it says it is...but it says that there is no ipod connected when i select preferences and the tab labeled ipod. what the hell do i do? i cant even update! |
jbhoops Unregistered guest | i need help my ipod mini starts up at the screen but then a file and a warning signe comes up how do i fix this? |
Gold Member Username: Project6Post Number: 3362 Registered: Dec-03 | Jess mariano Read the manual that came with your iPod. It will really help you out a lot. You really look like you could benefit from the reading. |
crackerjacker Unregistered guest | i was in diagnostics mode and i accidentally went to remote test and i don't have a remote. It froze and i don't know what to do. Ive tried plugging it in my computer, and also many button combinations. What do i do? |
New member Username: BarbaramaiaPost Number: 1 Registered: Aug-05 | hi, i've just got an ipod mini,and i let the battery charging for a bit over 4 hours,like its writen on the manual,but when i tried to turn it on, a lock appeared and the ipod froze saying "ok to disconect",i've tried to press the menu plus select buttom on hold,but it didnt quite work out...i havent used it! =( WHAT SHOULD I DO?HELP ME PLZZZZZZZ!! |
New member Username: WumingsdenNottingham, East midlands England Post Number: 1 Registered: Aug-05 | To jbhoops: This message comes up because you have completely restored (in other words deleted) your iPod. Simply plug up back up via USB or FireWire and it will automatically detect itself and then add the music you want. |
New member Username: WumingsdenNottingham, East midlands England Post Number: 2 Registered: Aug-05 | To Mallory Angel: You asked this - How do I get the songs on iTunes to my iPod Mini?? I am not a computer person, so say it in blonde-proof words. Thanksss. Plug in the USB and Itunes should automatically load. If not then you load it manually. Under podcast you should see the name of your iPod. In the library part put all of the songs that you would like and then one - by - one click and drag to the iPod icon. |
New member Username: WumingsdenNottingham, East midlands England Post Number: 3 Registered: Aug-05 | To anybody that would like to UPLOAD their songs FROM their iPod to their PC: To do this go on a search engine and type in iPod music liberator or EphPod Both of these programmes allow you to upload music from iPod to pc |
Unregistered guest | Hey to anyone who is able to help me. I dropped my ipod the other day and since then all that happens is the apple sign will come up and then an ipod icon with a ! sign next to it. I've tried resetting it but the same thing just keeps happening. When i connect it to the computer nothing responds either. I really have no idea what to do so if any one could offer any help i would be really grateful. Thanks alot. |
New member Username: Just_wonderingPost Number: 1 Registered: Aug-05 | Hey to anyone who is able to help me. I dropped my ipod the other day and since then all that happens is the apple sign will come up and then an ipod icon with a ! sign next to it. I've tried resetting it but the same thing just keeps happening. When i connect it to the computer nothing responds either. I really have no idea what to do so if any one could offer any help i would be really grateful. Thanks alot. |
elenaaaaaaaaa Unregistered guest | all the songs on my ipod mini are erased and when i plug it into itunes it says 'iTunes has encountered a problem and needs to close. We are sorry for the inconvenience.' so i dont know where to start to put my songs back on. it wont let me do anything in itunes....please help!! thank you so much! |
Anonymous | I am having trouble transferring songs from itunes to my ipod mini. It says it is updating and you see the bar but nothing happens? What can i do to get my ipod transferring songs? Thanks |
TewCool Unregistered guest | I love you all. This forum saved my life...and my iPod mini. |
Al Switz Unregistered guest | i'm really confused. my ipod mini isn't showing up in itunes for no apparent reason. it always has in the past and i haven't done anything to my computer or ipod. i tried it on different macs using different usb/firewire cables and the same thing happens ie "no ipod connected". when i go to disk utility however it is listed as a drive and the ipod is being charged and the "Do not disconnect" sign comes up indicating there is something connection. I've rebooted the ipod and sinced tried updating itunes/ipod but nothing happens. Any clues? Cheers |
devindangerxcore Unregistered guest | hey thank whoever posted the link to that ephpod way up there. I was having trouble with itunes reading my mini and stumbled across it. works great, thanks again. |
annonymous Unregistered guest | Does anyone else have this problem? I'll turn my ipod mini off (the screen goes blank) and I'll turn the hold on. Thinking its okay I'll walk away, but more times than not when I come back my ipod will be on and have played 60 some songs. While it's playing these songs the screen still shows the lock in the top left corner saying that the hold is still activated. If the hold is on shouldn't it stay off and not be playing music? How do I fix this? |
Charlieiscool Unregistered guest | to Courtney pang: I have the exact same problem as you. |
angel777 Unregistered guest | I just got an ipod mini and i can't seem to get songs onto it..i did everything exactly as I was supposed to and still no songs on my ipod. The screen on the ipod looks like its doing something, but once I check my ipod-there's nothing on it! What am I doing wrong? Or is it defective?Even on the ipod tab in iTunes it shows the songs I *thought* had been transfered to the ipod, but it says 0 songs on the ipod...I'm so frustrated, Please help me! |
MrSimple Unregistered guest | I just got my Ipod and i have uploaded the song and everything onto Itunes... but the itunes says finished updating but all the ipod says.... it blinks do not disconnect so i dont know if its uploading or if its doing something else.... any ideas? |
Gold Member Username: Project6Post Number: 3572 Registered: Dec-03 | angel777 open iTunes. Connect your iPod. On the left side of your iTunes window, check if you can see if the iPod is connected. It should show under "music Store" and it will show the name of your iPod (if you gave it one). Click on it. See if there are songs on the iPod by using the iTunes window. Then get back here. |
Gold Member Username: Project6Post Number: 3573 Registered: Dec-03 | Mr Simple, What is your OS? Did you designate a name for your iPod? (very important info) Answer these and we'll see what's going on. |
MrSimple Unregistered guest | Im takins OS as operating system(xp) and i did give my ipod a name |
Gold Member Username: Project6Post Number: 3575 Registered: Dec-03 | Open your iTunes. Are there songs on the library? |
Gold Member Username: Project6Post Number: 3576 Registered: Dec-03 | Do not connect the iPod just yet. |
MrSimple Unregistered guest | yes |
Gold Member Username: Project6Post Number: 3577 Registered: Dec-03 | now connect your iPod and wait for that verification tone that it is connected, or that the computer has detected it. |
angel777 Unregistered guest | I tried uploading songs to my ipod on a different computer and it worked perfectly fine. I wonder why I doesn't work with my computer... Its the weirdest thing on my computer b/c when I hook up my ipod to the computer and open itunes, the first songs that I tried to upload are shown on the ipod when I click on my ipod on the source list, but the only thing is that the songs are grey and can't be clicked on.. I also tried to uninstall itunes and everything..then I re installed it..same problem..I'm stumped.. |
Gold Member Username: Project6Post Number: 3579 Registered: Dec-03 | that is because your songs came from a different computer. The iPod will not let it transfer to another computer, that is why it is greyed out. iPod will not let you do file sharing. |
New member Username: Hanz1123Post Number: 1 Registered: Aug-05 | I need help...please. My Ipod Mini cannot even be recognized on my computer. It died and I am trying to restore it but when I connect it to my computer, the ipod doesn't even show which makes the restore option inaccesible. I am so majorly lost...someone please help this clueless ipod owner... |
Gold Member Username: Project6Post Number: 3583 Registered: Dec-03 | Define "died". Did you let it discharge...is it broken...did you drop it? |
angel777 Unregistered guest | No, these 'grey' songs where not from a different computer, they were the same songs I tried first that didn't get uploaded to my ipod...I'm sorry the way I wrote that before was confusing..![]() |
Gold Member Username: Project6Post Number: 3603 Registered: Dec-03 | Was iPod connected to a different computer before you hooked it up to yours? |
Clarkey_612 Unregistered guest | i was listnenin to my ipod when it was charging nd i tried to change da song nd it froze.The light is still on nd the play sign is up in da left hand corner but nothing is comin through da headphones. Wat do i do?? plz help |
Gold Member Username: Project6Post Number: 3636 Registered: Dec-03 | Do a reset. check apple.com on to how this is done. |
Unregistered guest | I was going to play a music quiz game on my ipod mini, and I clicked the button to play and it just froze and the hold button was not on. So I tryed to turn it off but it wouldn't, so now its still frozen and if I don't get it fixed i'll be in big trouble! Please help!!! |
Gold Member Username: Project6Post Number: 3661 Registered: Dec-03 | read the above postings on how to reset. |
Srinivasulu Unregistered guest | hi I had a problem with my Ipod mini and have resetted it but the main menu does not come up after that. I have also tried restoring the software but after connecting to the power supply, no display once more Can someone help? |
New member Username: TomdoakChattanooga, Tenessee Post Number: 2 Registered: Aug-05 | tried to tranfer my library from one computer to another and so i deleted the songs up to half way like apple website says to do. it didnt work and i still have an itunes file on my ipod and only some of songs are on there because the file takes up so much room. and i have tried to delete the file so i just want to know how to delete everything off the ipod like an ipod that ive just gotten out of the box. it is a 20gb 5th generation ipod |
Unregistered guest | Dude, I already had an iPod Shuffle and now I'm trying to get itunes to load up music on an iPod Mini and it's like not even reading the Mini, I've already updated Itunes to 4.9 but it still isn't seeing the Mini. Do I need the cd to install diffrent software. I dunno where this place is so if you can PLEASE E-MAIL ME!!! aliveorjustbreathing47@yahoo.com |
Bent Unregistered guest | Thomas . . just restore the ipod to factory settings YOu have ipod software installed on your sys You have the option to update the firmware or restore to factory settings, which is fresh out of the package empty. |
bent Unregistered guest | Thomas . . .. http://www.apple.com/support/ipod/tutorial/ip_gettingstarted_t15.html secondly Ive noticed on this forum almost every question can be answered off the ipod or apples website if not just searching through google. Im not understanding how you find this forum but you cant find the info through google. Which brings me to the answer. Your all lazy, you want answers but dont want to have to work for them. Ive answered several questions on this forum Feed your head and maybe the next problem may be easier to solve. |
