Just built a new dedicated home theater. The system has been up and running for about 10 days and no problems. However, just experienced a Denon 2106 receiver shutdown. Been watching TV for awhile and kids brought friends over to check it out. Popped in Star Wars I to watch the Pod racing scene. Highest volume before was about +4.0, but cranked to +8.5. Just as the scene ended, receiver shutdown (went to stand-by mode). I let it cool completely down, but keeps going back to the standby mode.
Equipment List Denon 2106 Receiver Belkin PureAV conditioner/ps Klipsch Reference Series RF-25 Fronts RC-25 Center RW-12 Sub RCR -- 5 Ceiling Side and Rears Toshiba Prog Scan DVD Mits 62" 1080p DLP
The Klipsch were and have been flawless. Was this volume too much for the maybe wimpy 2106? Wonder if I fried it? I checked all speaker connections for loose wire grounds (no banana plugs). I want to run this puppy again and willing to do what it takes (amps, new receiver, etc...).
I appreciate and welcome any and all comments/suggestions.
Greg: Most likely you have blown the protection fuses inside the receiver, if the unit goes into protection mode immediately upon the power button being pressed. These fuses are used to protect the amplifier circuitry and once they have been compromised the unit will not power on and remain due to the fact that the blown fuses cause a break in the circuit between the power supply and the amplifier(s). If the unit powers on completely but keeps going into protection then you have probably damaged the amplifier or output circuitry, transistors. For the klipsch speakers you mentioned, this unit is probably underpowered. You should not have to turn the volume control into the "+" range to get a loud volume. Once you get into the positive level of volume you are moving into clipping volume levels and the onset of distortion. This is very important to avoid. If the unit is under warranty take it in to be repaired,although the repairer may not cover the charges since this could be considered abusive use. If you must listen to movies at ear shattering levels you may want to scrap the receiver and purchase a strong multichannel amp, which will have much more headroom before clipping.
Check your spekaer cables for fraying. Post above is correct- if you need to go above 0 on a Denon volume control you have the wrong speakers or the wrong receiver. I use a denon and anything above -10 on the Volume dial reaches 100DB in my HT room.
Check your manual and the machine, Greg, I think that there is a mechanical reset that I saw once, but couldnt look it up here. Like a pop-out circuit breaker that wants to be pushed back in.
Nuck I think you are referring to the on/off switch,a longstanding,and useful tradition with HK receivers which will take the unit out of standby and completly disconnect the unit from the AC input. This is great if you are for example going out of town and and won't be using it for awhile.
Thanks for the comments. Looks like I "juiced her" a little too much. The Denon is covered under warranty, but since it will be in the shop for awhile, I went to a big box and bought a Pioneer VSX-815K for about $280. Sounds ok, but I did drive enough (-5 level) for the "overload" to activate and the system shut down during the same Star Wars scene. It did, however power back up...unlike the Denon. I guess I will look into getting a couple of Crown amps...say the xlr 202 for the fronts and center. Hopefully, this will be enough to get the sound I want. I also play live music, and I guess I just want the extra "umph" in my HT....or maybe I'm a little deaf from the Marshall amp and Les Paul days...
I double checked the Denon 2106 and no such reset button.
I've always liked the Klipsch sound and even had some huge La Scala's back in the college days. I also got the Klipsch due to what I thought as being very efficient and not needing as much wattage to drive the higher levels... any comments on this? Do you think the 202's will do the trick?
The Crowns will well assist you on your way to total hearing loss at the expense of sound quality of course, but hey if that is your cup of tea Greg then enjoy! Good luck!
