Speakers for a Rega Brio and Planet 2000 System-$1,000 Max
Volmoose
What speakers should I use with a Rega Brio and Planet 2000 System? I am willing to consider anything up to $1,000. I tend to listen to everything but rap and heavy metal. Bass response is important because I listen to Reggae.
Dynaudio Audience 42 or possibly 52 (but try before you buy since the bass may not go deep enough)
With your choice of music, you really want something a bit more efficient. The problem is that many efficient speakers aren't so hot on timing which is essential for good reggae.
