Rave mp
Username: Preinoso
hello.
I own a rave-mp arc 5.0 player. and it works fine, but now i get the sad face on the screen (uhhhh bad sign). I think that the firmware is lost from the hard drive, in fact it must be lost now because i reformat the microdrive to see if it has some errors, and its ok.
Can someone help me with the image of a good drive? i can use norton ghost to recover it
thanx
asfghdfhdfhsdfhsdf
ya i have the same problem, i tried to replace the harddrive, but it gives the same error, i email'd customer support and they dont know what it is
Username: Preinoso
the problem is that the firmware is stored in the hard drive... if you replace the drive you still doesnt have the firmware.
Username: Achueco
Buenos airesArgentina
Hi:
Does anybody know which AC/DC Charger use the Rave ARC 5.0? I've lost mine and I need to replace it. Only the generic stuffs Volts & Wattios .Thanks
