I have 2 Yamaha MX 1000 U amplifiers and was thinking of getting 4 Cerwin Vega Classic CLSC-215 speakers which have 2 15" woofers per speaker. Would this be too much for a 24' X 24' room or should I just go with the Cerwin Vega Classic CLSC-15 which has only 1 15" woofer per speaker?
If you buy only one pair of 15" woofers, you'll always wish you had popped for the extra pair. There's nothing that succeeds like excess.
Southern
Thanks Jan Good point, I was just worried that 8 15" woofers in a 24'X 24' room would be too much overkill as these amps are 260 watts RMS per channel. I have had trouble in the past with keeping a speaker that will handle these amps. I just don't want to make the mistake of getting the CV CLSC-215 speakers and then realize there too big. I like running 4 full size speakers, it just seems to sound better.
Has anyone purchased any of these Cervin Vega Classic Speakers yet, Classic CLSC-15 or CLSC 215? If so has anyone put any serious power on them as in 200 to 250 watts RMS and how did they perform? Im thinking of getting 4 of the CLSC-215 speakers and running them on 2 Yamaha MX 1000 U amplifiers but I would like to hear from someone who has put these through a good test with a power amplifier.
