Totally Green And Ignorant Newbie Question
Username: Kingofcopycom
Lutz, FL USA
Hey there,
I'd like some advice but be forewarned! I'm going to ask you some basic newbie stuff, and my knowledge base here is close to "zero".
I LOVE listening to music, but just like the guy who loves to go on long drives, but doesn't know anything more about cars other than how to turn the key to start the engine... I know nothing about stereo "stuff".
I Listen to mostly rock and blues -- with prominent guitar sounds.
Last year, bought my first subwoofer and fell in love with music once again.
Just stepped up my CD player to the Music Hall CD 25.2 and was astounded at the kind of sound improvement it made, even over my decade-old Polk Audio speakers.
Now inspired to upgrade my whole system.
So here's the $64,000 Dollar question:
Do I buy a "traditional" receiver, or do I buy an "amp" and a receiver?
And if so, or if not, where do I start looking for amps/receivers, and recommendations.
I know there will be pundits on both sides of the coin, and I'm open to listening, but I also don't have time to waste on stuff that won't benefit me for my specific use.
I DO have an extensive album collection, but mostly listen to CD's (which I know may be heresy to some).
Anyway, thanks for your patience and thanks for reading this message.
Happy Holidays, Craig (http://www.kingofcopy.com)
Username: Project6
Post Number: 4546
Budget?
Username: The13thgryphon
Spokane, WA USA
Post Number: 11
There are some very nice integrated amps out there... from very inexpensive to outrageous. Something along those lines would probably be my recommendation. I'd stay away from receivers if you want the best sound qualify for your dollar. However, like Berny said, what's your budget?
Username: Jan_b_vigne
Dallas, TX
Post Number: 7004
Where'd you buy the Music Hall? Are you uncomfortable going back and asking their advice? We have no idea what products are avaialable for audition in your area and I would think anyone on this forum would suggest you listen to a piece of equipment before you make a purchase.
Lutz, FL USA
Great feedback.
I'd say my total budget for both would be around $700 bucks, but thinking this through, I'd probably get more bang for my buck plopping $500 bucks into an integrated receiver, no?
Keep 'em coning and happy holidays!
Thanks, Craig
Username: Nuck
Parkhill, Ontario Canada
Post Number: 815
Craig, you will never go wrong with a Harmon Kardon receiver.
For 700bucks, you can get a kick-butt unit, espicially this time of year.
The H/K might offer advantages that you don't need right now, but may well need in the future.
Check them out
Daniel34
"I LOVE listening to music, but just like the guy who loves to go on long drives..."
Craig, if music is your priority and your budget doesn't increase 3x at least, I'd forget the receivers and go for integrated amp. The difference you'll get even with half decent source is incredible....speaking from experience, but again just my two cents.
Good luck.
