Anonymous | An earlier thred listed some receivers, and a few posters listed the Cambridge Audio 540 at the top of the list. WHY? Where can I find any reviews on this unit. It will be impossible for me to listen to the unit, no dealer in my area. |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 2489 Registered: Feb-05 | http://www.audioreview.com/cat/amplification/a-v-receivers/cambridge-audio/PRD_2 99482_2718crx.aspx http://www.homecinemachoice.com/cgi-bin/displayreview.php?reviewid=4344 Our local dealer quit carrying this receiver due to the high number of QC returns. I have heard however that they have turned the corner on those issues and been putting out good product. They have a new model coming out soon I'm told. |
Amti Unregistered guest | Art,which HK model would be considered as a comparable with the CA 540? I have had a HK 510 for almost 4 years now and was considering a replacement. The 635 is really expensive and im not sure i really need it. The CA 540R is about half the price but seems similiar in terms of output and seems to be sounding good too. Is it a good potential replacement inur opinion?? |
Gold Member Username: ArtkAlbany, Oregon USA Post Number: 2533 Registered: Feb-05 | If I were you and could spring for it I would consider the Outlaw AVR. Less risky and probably better sounding in every way than the Cambridge. |
Amti Unregistered guest | Unfortunately i live outside the US so i cannot order Outlaw.... :-( |
Amti Unregistered guest | Hey can u really compare the HK635 and the Cambridge 540R? I live in India and here the Cambridge is less than half the the price of the HK. Its half the size too but i dont know if that means anything....maybe its more in line with the HK 435? Does anyone have any opinions on how it compares with the NAD 753? |
Amti Unregistered guest | Hey Amti - sorry i wanted to write to u and by mistake entered ur name as username!!! didnt mean to be an imposter!! This message was mine............. Hey can u really compare the HK635 and the Cambridge 540R? I live in India and here the Cambridge is less than half the the price of the HK. Its half the size too but i dont know if that means anything....maybe its more in line with the HK 435? Does anyone have any opinions on how it compares with the NAD 753? |
