Which of these 3 would you choose?
Outlaw LFM-1, $579
Hsu STF-3, $600
Mirage OM-200, $400 (list $1000) has interesting dual driver design but I am a little skeptical of the size (8") and modest weight/size.
I am looking at 60% music, 40% movies usage in a medium/large upstairs gameroom, open floor plan. Tight accurate bass is nice for music but I'd like to feel some real oomph during movies too.
Username: Davidpa
Portland, Oregon US
Post Number: 62
Outlaw would be my choice. Will rumble nicely, you wont get "real tight" with much in that price range, for that your budget will need to increase.
Username: Artk
Albany, Oregon USA
Post Number: 2486
I agree with David. The Outlaw is designed by Dr. Hsu and is more competitive with the Hsu VTF3 MK2.
what do you guys think of using two LFM-2s instead of one LFM-1?
I have read that some people put two smaller subs side by side to get greater SPL but retain more control and accuracy due to the smaller driver, because it is sometimes tricky to have two subs farther apart in the same room without them interfering with each other.
Username: Edster922
Post Number: 3448
I'm in the exact same boat, am currently leaning towards the LFM-1. Was told it's a newer design than the STF-3 and should be slightly better for music with the downward ports.
I haven't heard that the LFM-1 is competitive with the VTF-3 though. I do know the VTF-3 can go all the way down to 20Hz whereas the LFM-1 is tuned to 25Hz.
Is Orb (2 x Super Eight Custom Subwoofers) better than Outlaw (LFM1 + LFM2)?
Username: Artk
Albany, Oregon USA
Post Number: 2553
Probably not.
