Bookshelf speakers
dave in Pa.
my wife has an onkyo receiver tx 906...and wants a pair of bookshelf speakers. they can be up to 7 1/2" wide.
she presently has an old pair of floor model HK speakers from an old all in one system.
one stereo shop i called has paradigm atom for $200
another has polk 30...same price
can you recomend any others or are these ok...
i'd prefer to stay in the less than $200 price range
thanks...Dave
Username: Chitown
Post Number: 577
You can try the Aperion Intimus 422-LR. A set of A-stock will cost about $180 shipped.
Username: Gavincumm
New York USA
Post Number: 445
the paradigm atom will be a better bet than the aperion if you don't want to use a sub. They can be used alone for casual listening to my ears.
Username: Edster922
Post Number: 3447
Wharfedale Diamond 8.2s from buy.com
or
Athena AS-B1s from audioadvisor.com
Username: Chitown
Post Number: 587
Wharfdales are bigger than the size he specified.
Can't find much info on the Atom on the Paradigm website.
I would also recommend the Monitor Audio R90. They work very well without a sub, but you would have to go to the $300 range for them.
Username: Gavincumm
New York USA
Post Number: 446
take it from someone that HAS the atoms (ie: myself) that they work very well for casual listening without a subwoofer.
