How do i turn a pc speaker set into center channel speaker? is it possible?
Username: Jinster
Post Number: 19
i got harman kardon soundsticks 2 that's just sitting around and would like to turn it into a center channel speaker connected to denon 3805 replacing my crappy onkyo speaker. would this be possible? if so then how? thanks.
Username: Fusseli
find the impedance of your comp speakers and see if you can arrange them to match acceptable levels for use on your receiver. wire them straight in and be gald it works :/
Username: Jinster
Post Number: 20
my receiver had a pre-out for powered speakers and i managed to wire it succesfully. however, i realize that the soundsticks were meant to be heard only within 6 feet of the sound range and since i sit more far from that when it's being used as a center speaker, the sound seem to be rather 'unnatural'. am i just imagining this since i'm such an amateur or is this the truth? Thx
