For bw n805?
ererererer
What is a better option for the N805 among the Krell KAV400, Creek 5350ES and the Creek Destiny?
Thanks
ererererer
Any help?
Username: Jan_b_vigne
Dallas, TX
Post Number: 6937
Are those our only choices?
ererererer
Best price options in Mexico
What is the recomendation among them?
Thanks
ererererer
Thanks
Username: Artk
Albany, Oregon USA
Post Number: 2465
Actaully I've heard both Creek and Krell often with B&W and both work remarkably well. My most recent experience was with Krell Reference series products and the new "D" tweeters on the 800 series B&W's. It was fabulous! Last time I heard a KAV integrated it was with Martin Logan speakers and again it was outstanding. I listen to the Creek 5350SE with the B&W 700 series floorstanders nearly every weekend and that is a great match. If you can listen to them both and choose. If you haven't that option and can get them for a similar price buy the Krell. If the Creek is significantly less money, it's not significantly less amp (besides the power) and may be a better choice.
ererererer
I can get the krell for 2800 and the creek ES for 1600 both new
Thanks for the advise, i was expwcting that then incremental benefit is not worth the incremental cost
Any other comments?
