I just wired up my 5990. It works good except that I have an LG HD tuner/HD DVD player. The video through the HDMI on the receiver wont work when I watch dvd or locals in HD. It says that it is non HDCP compatible (which the unit and my TV are) and then the HDMI light on the receiver blinks. Anybody have any suggestions????
ranjen3834
Try this, turn everyting off. First turn on 5990, then which ever component you want to use. I had the same problem with my sat. reciever.
