B&W 603 S3
Username: Petro
Post Number: 15
Just got pair of used B&W. 2 problems.
dome of tweeter (light silver metal) has indentation crater (1 cm diameter and 4 mm deep). How to fix it? I heard of tape, vaccum etc. If it is not touching the magnet (how would I know) can I leave it as is?
Second, binding posts have plastic plugs that cover the 4 mm bannana slot (because bannanas are not allowed in europe (safety)). How to remove them? they are pretty tightly inserted. Any special trick?
thanks
