Not really because accessories are often system dependent. What works in one system, may not work well in another. The best suggestion is to only buy these items when you are guaranteed return privileges if you are unhappy with the results. Let your ears decide what works best for your system and don't rely on a web site for this one.
hi i am a noob at diy audio systems i was wondering is it possible to convert speaker cables to phono cables... ie you get a + & - cable from each speaker can each set of + & - cables be soldered into individual phono cables ... or even better can u just buy that sort of cable if so what is that sort of cable called or has some one got a link to a site that stocks them cheers guys ( hope my discription wasnt too longwinded lol )
