Hi i just got a pioneer elite vsx-49 not TX or TXI without a remote controller. But one channel side is alot louder than the other side. ANyone have any ideas on how to fix this. Mayb theres a way to reset the receiver :p Thank you.
its a simple fix if it is what i think it is. When you come into the menu, there is a decibel level setting that you can adjust each speaker and woofer by, it sounds like they turned up one side more than the other or didn't set it up right at all. I would just pay the money and get the remote from Pioneer, life is tough on any receiver with a remote to help you through the setup.
thnx so much i looked up the remote it costs almost 100 i bought the receiver for $71. Hopefully i can find a universal remote or somehow get to the menu w/ the buttons on the receiver.
