I have a not so sweet receiver (out of the box surround sound style) that has a frequency responce of 100hz - 20khz / -3db. It pushes 85 watts per channel RMS and has a signal-to-noise ratio of >65 db (CCIR). I was looking at a pair of bookshelfs I planned on using as replacement fronts for a 5.1 surround system in a small room, and for listening to music. The specs on the bookshelfs are 90db sensitivity and 60hz - 20khz with a 125 watt (per bookshelf)power handling. Will the not so hot response of the receiver cause a loss of sound quality with these speakers? is this a decent match? HELP ME PLEASE! YOU ALL SEEM SMART!!!
