Help! h/k avr430 or marantzsr5600
Username: Gordo_in_ns
ive got 4,6,8 ohm speaker package and im trying to get some sound in a large room. anyone have an opimion?
Username: Nuck
Parkhill, Ontario Canada
Post Number: 696
Gordon, how did you end up with such a mix, more importantly, what kind of speakers do you have, and what is your goal?
I presume 5.1, but what do you want to accomplish?
gordo+in+N.S.
thanks for replying, i have the axiom epic 80 surround package. im just looking for sound quality
Sorry had a hard time logging on, rookie misteak.
Username: Nuck
Post Number: 700
Very tough to gauge, that package.
Doesn't Axiom recommend power for that set-up?
Do you have a 350, or a 500servo sub with it?
Did you see the 600 servo?..Yikes!
You really need serious hydro for that setup.
I suggest you call Axiom for recommended power, it will be a lot to maximize what you have.
In a hall.
Or stadium.
they said to pick the h/k or to check out the
vsx-101015tx (pioneer?). the sub is the 350. a friend of mine won the system online so i got it for 1200 canadian
my current reciever is a sony (is that a bad word)strk-850p. i have one friend who knows a bit about stereo stuf and his advice was to pick the heaviest reciever. Heres the lowdown ive got to be at or under 1000 dollars including tax. ID LIKE TO FIND THE BEST FOR THE BUCKS. aNY SUGGESTIONS?
