Subwoofer size question
Kar
Is there any rule of thumb on what is the appropriate size of woofer reqd for a particular room size? I trying to decide between Velodyne CHT8 and Velodyne CHT10 for a moderately sized apt with wooden floors. Listening area is about 10'x12'. Mainly for movies.
Thanks
Username: Feot
Houston, TX USA
Post Number: 8
Either would be sufficient for an apartment. I usually don't install anything larger mainly because you will have complaining neighbors. In either case, since the Velodynes are forward firing, you would want to aim the speaker toward a corner or a wall, not facing you. Let me know if you want some more options or want a price.
Jan Vigne
Kar - Start with the smaller sub first, you can always exchange if you feel the need. See my answer to "Need sub help" for more reasons why this makes sense.
Kar
Thanks. I ended up buying the CHT10 since the price diff was only $20 between the 8in and 10in. I will have to place it in the corner as I see form the above post. I current have it next to my fronts.
Thanks for your advice.
Kar
