should be fine for HT, I just wouldn't expect much for music. If you want to stay analog, you'd be better going off with an HK 135 or 235, IMO.
just trying
Can you spring a bit more for the vsx-1015 or one of the bigger H/K's? Sound wise, the 135 or 235 will be fine but with such little features, mostly in's and out's, you may need to upgrade sooner than later anyways. But, that depends on how much you will in fact use. My H/K 330's digital in's are full, all the composite in's are full, and I still have more gear I want to use! Just think and plan ahead that's all I'm saying.
P.S. If you're gonna buy an H/K online just buy a refurb from H/K's direct site. You will save alot of $$$.
avcrazy
Thanks alot guys. i'll think about it. i'll audition all, then make a point.
GBU all.
Amti
How would the CA 540R compare with the HK 635? On paper it sems more powerful but looks really small in size.......
