Want to put together a Home Theatre 7.1 or upwards
Hi want to put together a Home Theatre system 7.1 or so. Budget is shoestring.
Username: Edster922
Post Number: 3277
a. What % of your usage will be music vs. HT (home theater)?
b. If your usage includes music, are you planning on doing a lot of multichannel SACD or DVD-A music, or will it be primarily 2-channel listening?
c. What types of music do you listen to the most? (classical/jazz, rap, rock, etc.)
d. What types of movies do you watch the most? (action/thriller, drama/comedy, etc.)
e. How big is your listening/viewing room?
f. What kind of receiver/amp will you have?
g. Do you have a subwoofer or plan to get one?
h. What's your absolute maximum budget vs. hoped-for budget?
