What kind of amp should i get?
Username: Bumpingirl
alright. so i have two 10in. subs from kenwood gettin about 600w a piece. what kind of amp should i get? stick with kenwood and get an amp from them? or would it sound better from somewhere else?
it would sound much better at the pawn shop. Also, take any other electronics you have and hock them all. If anyone tends to leave watches or jewlery laying around, take than too. Your final goal will be to get an Onkyo 8511 and a Velodyne CHT15. It doesn't matter if you don't have enough for monitors you WILL be Bumpingirl then.
Username: Project6
Post Number: 525
right now they shouldn't be getting any "watts" at all, seeing that you are looking for an amp. Do you have a budget??? Is this for a car?, if it is, you are in the wrong forum.
