I'm sure that the subject is confusing, but here is my question.
I'm about to have my new HDTV delivered tomorrow. And the speakers in the set are probably far better than what I'm using for my center/left/right speakers from my receiver. My question is this, is it possible to use speaker wire with RCA jacks to plug into the Inputs for left and right audio on the Set. I don't want to take any chances on damaging it, so I'd like to get some expert advice on if this is even feasible or only trouble before I try it.
I think you mean you want to snip and strip some RCA's to use right? I wouldn't. On my old samsung tube TV I tried it and nothing happened.... I assume that it wouldn't work.
