PSB tweeters
Username: Nuck
Parkhill, Ontario Canada
Post Number: 558
I called PSB, looking to replace the metal tweeters in my stratus silver towers with soft domes, nothing seems to match.
Any Ideas for a transplant?
One question: Why?
Username: Nuck
Post Number: 560
The metal tweets are a bit harsh, as compared to the soft dome of the center, and I love that sound
Username: Nuck
Post Number: 561
vooldemort
Ask them for a couple of those soft domes that are in the center then? Other than that there is always partexpress...
Username: Nuck
Post Number: 562
Tried that, but noluck.
Try partsexpress, but I dont dont to play with them too much...maybe just some resistors
Thanks a bunch!
Username: Edster922
Post Number: 3207
Nuck, what model PSB towers do you currently own?
Username: Nuck
Post Number: 565
Stratus Silver, about 8 yrs old.
The newer model is Stratus Silver i, but the tweet is the same, according to parts dept.
Username: 2morex
Exmore, Virginia USA
Post Number: 35
Nuck: I once had a pair of nht 2.4s and wanted to do the same thing. Was strongly advised by tech service at nht not to attempt such. So, out went the metal domes, towers and all. I liked the nhts at first but then they just got to be too much for my old ears. Guess you may be in the same boat.
Username: Nuck
Post Number: 566
I am not sure, RD.
I only changed the wiring a bit, a tip from Frank Abella, after he saw some pics on my site.
I still had the binding strips on the bipoles, and he suggested I replace with speaker wire, then send the + to the tweet+ and the - to the bass -.
The difference was dramatic.
Now I wonder if I have opened a can of worms.
Username: Nuck
Post Number: 567
If I swap them out, I think I might mount the resistors from the XO's externally on posts, to be able to swap them as well, tune them in.
I have not actually seen canned worms, though.
Username: Nuck
Post Number: 569
Vooldemort might be spot on after all...
Username: Nuck
Post Number: 576
PSB called back, and suggested the domes from the 600 -1000i series, but caviat, no guarantees.
no sweat, got the name of the guys making their XO's, and the guy there is more than happy to make me an open air inductor to replace the iron cores now present.
Gets better all the time!
Username: Nuck
Post Number: 577
PSB is shipping the soft domes, fit not guaranteed, an Hanlan Componants, who make the XO's are sendin, no charge for trial, open air inductors.
The engineer there is a sound guy, and will review what I have and suggest parts for a new XO for my set-up.
You Betcha!
