New member Username: Nik3Sacramento, Ca Usa Post Number: 4 Registered: Nov-05 | wana get one o these subs to match my sony floor speakers were as the vx-10 is one of velodyne lower end subs the wx700 is one of sonys higher end subs in the same price range but i wana get the best one ??? help |
Bronze Member Username: DavidpaPortland, Oregon US Post Number: 11 Registered: Nov-05 | velodyne by far. |
Bronze Member Username: Nik3Sacramento, Ca Usa Post Number: 20 Registered: Nov-05 | now all i need to figure out is the place ment i got a weird room if i go by the door way there is just mass amounts of bass coming from my old 120watt klh if i move to the middle of the room the only bass i here is the bass from my sony towers then if i chill on my bed it like 50% from were the door way is i think a better velodyne will fix it cuss then i could put it in the frount along with the towers if i can fit it the sonys are like mica's very large for my room and sine the velodyne is sheilded i can run them there but then if i put the sub against my tv side will it cuzz any damage to the set i have a farly new sony trinatron 32" i just dont no or do i put the sub were the klh is hoping that the velodyne fills the hole room with bass? |
Bronze Member Username: DavidpaPortland, Oregon US Post Number: 14 Registered: Nov-05 | with just one sub, its fairly easy to just move around and find best spot, I just had this problem with two subs cancelling each other out, Jan Vigne was able to help me out with some articles, I will see if I can find them and paste them here for you, Or go over to speaker forum and look for thread "why", that might help. |
Bronze Member Username: Nik3Sacramento, Ca Usa Post Number: 21 Registered: Nov-05 | ya a was going to keep the klh also just love the sub for some resone but she geting to be a year old and was a piece of the old regien lol. |
Bronze Member Username: DavidpaPortland, Oregon US Post Number: 15 Registered: Nov-05 | http://www.harman.com/wp/index.jsp?articleId=131.0 http://www.harman.com/wp/index.jsp?articleId=1003.0 http://sound.westhost.com/subcon.htm http://www.audioc.com/library1/subprimer.htm http://www.sonicdesign.se/subplace.html check out these links, I think they will help you. Good luck, Dave |
Bronze Member Username: Nik3Sacramento, Ca Usa Post Number: 29 Registered: Nov-05 | thanks for your help ![]() |
