Will it play 6.1 if it only says 5.1?
Username: Catunderstar
I have just bought a panasonic s97s dvd player. It says it is 5.1 sound compatable. Will it only convert to 5.1 or will it work with 6.1, 7.1??
Username: Arnold_layne
MadridSpain
Post Number: 433
AFAIK the s97s has 5.1 analogue output, which means it cannot possibly deliver decoded sound for more than 5+1 channels.
But dont worry. 6.1 audio (i.e. DTS-ES and Dolby Digital EX) is encoded in such a way that non-compatible gear reads it as ordinary DTS or DD. This means you just need put it into an ES/EX compatible receiver, using one of the digital interfaces. The receiver will decode it correctly as 6.1.
7.1 works in a similar way. Actually I think it is just a matter of splitting the sole rear channel into two speakers.
Cheers
AL
