Is scs150 that much more compelling than scs-135? Main differences as far as I can see from the specs: 8'' vs 10'' subwoofer, 35Hz vs. 30 Hz lowest frequency, 86db vs. 88db, small sats vs. bigger sats. Any other speaker system I should consider for a 3000 cu.ft room (12x25x12)? Size of sats is a consideration. Would like to stay within scs150 size.
Thanks, Hari
jay gillespie
I've got the scs150 at best buy and they gave me a real good deal. the scs150 alone i think was around 450-500 bucks and a yamaha reciever for 550 and they gave me both for 800 bucks. I then added JBL 2-Way 5" Center-Channel Speaker and put that up front and moved the center channel from the scs150 to the rear. So now I've have a great loud 6.1 surround sound system. The scs150 comes with a convient set of wall mounts but if you want stands check out jbl.com they have real nice ones you can buy. Wow and I just notice your post if from january haha.
