Need high out put amp
Hello
I need some help.Which used amp would be best for over 200 wpc.I have the sony 5000es powering 2 front 100w yamahas, 2 rear wharfedale 100w, 2 rear 200w wharfdale. I want to pre out to an amp to power 2 front psb 200w 5t's and a 200w wharfedale center.If i get a 5 channel amp i will power the rear wharfdales as well.I want clean high power sound for around $1000.00 or a little better.
thanx in advance for help
Shawn
Username: Nuck
Parkhill, Ontario Canada
Post Number: 512
Shawnster, you may want to consider several Panasonic xr55 units together. That would satisfy your need for power at your price point.
Otherwise, shop used stores, you may not find that kind of product for that price.
im gettin 2 Audiobahn AW1206T 12" Subwoofers they are both dual voice coil and 4 ohm. they RSM max at 1100 watts, i need a high powered AMP and i can't find anything that sound like it and push good enough. i need to find an amp within $1,000.... can anyone help me?
Username: Gman
Mt. Pleasant, SC
Post Number: 743
Shawn- Go to audiogon.com and look under the multi-channel amp section.
