I'm looking for outdoor speakers that I can mount inside the wall. All the outdoor speakers I've seen are wall mounted. Anybody run across in-wall, weatherproof speakers that you would recommend?
Most in wall speakers can be mounted outside. A typical in wall is designed to be used in high humidity such as a spa or bathroom. If they are protected from direct exposure to the elements, you should be able to use whatever speaker you prefer. You may end up replacing them slightly sooner than a more conventional outdoor speaker; but no outdoor speaker will last forever anyway.
