Digital or Optical connection?
Username: Exerciseguy
Brooklyn, NY USA
Post Number: 261
What are the pros & cons of a Digital Audio vs. Optical connection?
Username: Rysa4
Post Number: 126
Are you referring to Coaxial cable vs optical Cable, or vs DVI and HDMI?
Brooklyn, NY USA
Post Number: 263
Coaxial vs. Optical for audio-only applications. I'm aware of some of the pro & cons, but would appreciate any insights.
Username: Rysa4
Post Number: 135
OK- These are my opinions; The audio quality is for all practical purposes identical. The optical cable is a bit more fragile on the ends imparticular so be careful with those. Its more common to find optical than coaxial connections on devices because it is cheaper to build an optical port than a coaxial. But its nice to have both. Seems like I am forgeting one comment about coaxial. Oh well. Gettin old I suppose.
