I will be picking up my NAD T763 on Tuesday. I understand that this receiver has 3 component video inputs and a component video output. If I run all of my video sources (HD Cable, Yamaha DVD-S2300MK2 Player, and Sony 400 disk CD/DVD changer) through my receiver, will I lose video quality?
My TV has only 2 component video inputs and the 3 inputs on the receiver are looking very attractive.
No not at all, the Components on the T763 are ready for high bandwidth pass through!
St. Louis Blues
I have the NAD T763- but haven't upgraded to HDTV yet. I use the receiver to switch sd satellite, xbox, vcr, and dvd using s-video and composite inputs with no problems.
I haven't seen the spec for bandwidth- but understand it will handle HD. Anyone verified this yet?
the bandwidth spec on the NAD is 50 mHz. is that adequate for HD (1080i)? some other receivers have more, for ex. HK 7200 is 100 mHz, i believe. how much bandwidth does one need for HD?
