Never heard of nad before this board
Username: Bill984
Post Number: 43
how would one of their recievers compare to the denon ar3806?
Username: Jan_b_vigne
Dallas, TX
Post Number: 6710
Physically, they are about the same size. Typically, they are different colors, however.
I think we all know that you know that we all know you know more than that.
Dallas, TX
Post Number: 6711
That may well be.
However ...
I don't know any more now than anyone else now knows about what I, and we, would need to know before I, and we, could know I, and we, had given an answer based upon what I, and we, know to be well known considering what I, and we, now know and now do not know and what I, and we, now know I, and we, do not now know.
At least, for now.
I, and we, might know more later.
But, I, and we, don't know it now.
No?
What would be nice is if someone who knows what I, and we, would need to know would ask if I, and we, could know it now.
Now ... would be nice.
No?
Happy Holidays to you and yours.
Username: Bill984
Post Number: 47
if i knew now what i didn't know then, i wouldn't have asked the question.
Username: Artk
Albany, Oregon USA
Post Number: 2310
NAD's are sonically superior to the mass market brands like Denon, Marantz, Yamaha, HK, and Pioneer. Unfortunately they come with a few warts. They usually have an audible hiss and hum through the analog board. They've tried to improve and have to a certain extent but it was too much for me so I opted to change horses. Honestly no AVR short of an Arcam or B&K will deliver the goods for music so I would choose the one with a feature set and sound you can live with.
Username: Edster922
Post Number: 3068
Bill,
btw the vast majority of QA issues with NAD gear have come from their AV receivers not their 2-channel equipment.
I have some NAD 2-channel separates and have not experienced any inordinate "hiss and hum" beyond what is fairly normal with any *analog* gear in this price range and under.
Username: Chitown
Post Number: 486
Art how do you put Marantz in the "mass market" group like the rest of those brands. I don't know about the rest of the country, but There is only one store in Chicago that actually carries Marantz.
Username: Artk
Albany, Oregon USA
Post Number: 2319
Marantz and Denon can be had in a whole lot more stores here than Yamaha RX-V series receivers. I would not buy any receiver at BB and CC so I don't consider them in the mix. I really meant that relative to sound quality, build quality and exclusivity they are similar. HK and Pioneer can be had in the most stores here. Then would come the Yamaha HTR series followed by Denon and Marantz. The most exclusive of the bunch would be the upper end Yamaha's and Integra's. I can buy Marantz at a half a dozen or more stores within an hours drive of my house I can only buy the upper end Yamaha at one.
Upper end Yamaha
Talk about about an oxymoron!
Username: Konoyaro
San Francisco, CA United States
Post Number: 25
Bill, if you'd like to sample one of many threads on this general topic you might start here:
https://www.ecoustics.com/electronics/forum/home-audio/38081.html
Username: Artk
Albany, Oregon USA
Post Number: 2324
I owned the NAD T763 and believe me the "upper end" Yamaha can perform on a par with it for most applications.
Username: Smitty
Post Number: 255
Art, when you say "upper end" Yamaha does that begin at the RX-V2600, RX-V4600 or RX-Z9?
Username: Artk
Albany, Oregon USA
Post Number: 2325
Yeah, those really are the upper end Yamaha's. But relative to how difficult they are to find I meant all of the RX-V series and up.
Username: Chitown
Post Number: 495
The upper end of most of these brands are hard to get. I doubt any of the Marantz dealers will carry their Reference series which start at $1800 for a turntable. They are just too expensive to keep in inventory.
Username: Smitty
Post Number: 261
Art, I'm just curious if you would consider something like the Yamaha RX-V2500 to be on a par with the NAD T763 for CD/DVD-A/SACD with relatively efficient speakers (95db fronts, 93db center, 91dB surrounds) ... or by applications did you mean HT? Would you consider the RX-V2500 to be in the same "sonic league" as say the HK AVR435/635 or a step above? I see the RX-V2500 did get a very good review over on audioholics:
Yamaha RX-V2500 Review
In my neck of the woods the HK AVR435/Yamaha RX-V2500/NAD T743 are all around the same price, the NAD T763 is double the price. I figured the NAD would be the best for music, Yamaha best for HT and the HK would be somewhere in between.
