Yes, Marantz can drive 4 ohm speakers
Username: Patnshan
Wisconsin USA
Post Number: 13
For an answer to all the questions about whether a Marantz receiver can drive 4 ohm speakers or not I wrote marantz. The answer from them is that my SR-8400 can drive 4 ohm speakers without any trouble. I guess I can look at the Epos more seriously now!
Pat
Username: Jan_b_vigne
Dallas, TX
Post Number: 6664
Did you ask if that applies to a "4 Ohm" speaker that dips to 2.5 Ohms?
Username: Patnshan
Wisconsin USA
Post Number: 14
I did not. Their response was:
Patrick -
The SR8400 should be able to drive 4-ohm speakers without any problems.
Thanks
Jordan Schultz
Marantz Support
I did not ask about dips lower than that. For my purposes, the Epos does not dip below 4 throughout it's spectrum, I am told. You may try an e-mail to them, I got a response in less than an hour.
Pat
Dallas, TX
Post Number: 6667
Patrick - Since I own neither a Marantz SR8400 nor a speaker which dips below 4 Ohms impedance, I'll leave it up to the next person curious about this matter to do the asking. I do, however, find Marantz's answer to be quite bold considering the variability of how a "four Ohm" speaker might load an amplifier. Good luck with your system.
Username: Patnshan
Wisconsin USA
Post Number: 15
Jan,
I agree. I would have liked a bit more definitive answer as well. I do know Tawaun on this forum reported the EPOS not going below 4 ohm ever, I am unsure of other "4 ohm" speakers.
I would hope that the answer from Marantz has been tested by them, not just a guess. I guess I can use that e-mail as ammunition for my claim if my receiver gets hot and blows running a 4 ohm load:-)
pat
Username: Nuck
Parkhill, Ontario Canada
Post Number: 466
Let er go Pat!
I know HK will do it.
How about a speaker that dips down to 2.5 ohms, then swings to 30 ohms, then back down to 2.0 ohms, then back to 25 ohms!
Username: Nuck
Post Number: 470
Anon, you want fries with that.
A hammer isnt the tool for every job, you know.
Username: Patnshan
Wisconsin USA
Post Number: 16
Got another update:
Patrick,
If the speakers are stable at 4-ohms, there should be no problem using
them with the SR8400. The impedance of some manufacturer's speakers
will very quite a bit across the frequency spectrum. If the impedance
should drop to 2-ohms, the receiver will respond by going into PROTECT
mode, especially at high volumes. This is a built in self-defense
mechanism that prevents damage to the units power amps.
Best regards,
Kevin Edwardson
Marantz Technical Support
The Epos are stable and do stay above 4 ohm's according to the stereophile measurements.
Pat
