Headphone wiring
My headphones stopped working the other day so i took them apart and found that alost al the wiring had come apart.
Now there are 3 wires coming from the plug, 1 i assume is ground and the other 2 are left and right, the only problem is i don't know which is which.
The 3 colours are red white and black.
The red wire goes into the right speaker im just not sure if it is ground or thr right side. any help?
Also is there an easy way of connecting the wires if i don't have a soldering iron?
