Recording from vinyl to Sony RCDW100
Hi can anyone help - I have recorded off records and onot the CD recorder but it will only playback in the deck I recorded on, and i want ot make MP3s. Apparnetly i need to "finalise" the disc" or osmething - how do i do that? Any help much appreciated
Geoff
Username: Turbodog
Post Number: 54
I recommend you read the operation manual for your equipment. If you don't have it, you can download it here:
http://esupport.sony.com/perl/model-documents.pl?mdl=RCDW100
Username: Tetonbound
I make vinyl-to-CDs from a Pioneer stereo burner (PDR-609). The CDs will work in all machines save for Sony (will work in walkman types however). All I can say is its Sony, one of the firms most aggreesive about copyright protection. On the other hand, some CD players will only accept Orange Book standard CDs, ie 74 minute length CDs. If you are using an 80 minute CD, that could be the issue.
Need to Register?
Forgot Password?
Enable HTML code in message
