Posted on Anyone got a suggestion for a cartridge for a P3. About middle of the road, maybe on the higher end? Thanks for the help |
New member Username: Johnnyesox
Glasgow,
Strathclyde
Scotland
Post Number: 2 Registered: Nov-05
Posted on Check out a Linn k9 or something from Goldring on E.Bay?You might even pick up a mint con.Rega Bias/eyls....cheers |
Gold Member Username: Frank_abela
Berkshire
UK
Post Number: 1066 Registered: Sep-04
Posted on Grado Prestige Gold Ortofon 530 or 540 Dynavector 10x5 (a bit steep possibly, but works well) All these carts need a 2mm spacer under the arm to sort out VTA. Regards, Frank. |
New member Username: Michael_orme
Uk
Post Number: 1 Registered: Nov-05
Posted on Goldring 1042 is a safe bet. About £120. Linn don't do the K9 any more, it was only a badged Audio technica any way. Michael Orme. Rhyl. UK |
