Switching to 2-channel on panny
annonymouspannasonic
i have a panasonic xr-55 and was wondering if there is a better way to switch from 5.1 DTS to 2-ch stereo mode. Each time i switch it, i have to go into options and change which speakers i have (LCRS-Left,Right,Center,Surrounds or LR only). is there an easier way than constantly changing the options setup?
For DVDs, it's better to just select the stereo mix on the DVD than to downmix a 5.1 mix to 2.0. Or, doesn't your receiver have a stereo mode?
Username: Edster922
Post Number: 2944
AP,
so you want to watch 5.1 movies in 2.0 even though you have 5 speakers? why???
annonymousathena
no movies in 5.1 and music in 2.1, is it necessary to go in the options menu and change back and forth when going from music to movies or viceversa
Username: Edster922
Post Number: 2957
If your CDs are already in 2-channel the Panny like any other receiver will automatically detect that and go into 2-channel mode. The subwoofer will always be active as long as you have the subwoofer setting at "yes."
