Switch-Box to connect outside speakers to inside sterio
I used to use a Radio Shack switch box to connect outside speakers to my primary sterio system, but the box worked terribly. I want to be able to connect two sets of speakers into the box, and designate whether signal is sent to one, the other, or both. Does anyone know of a high-end box that can help? Thanks
an A, B and A+B switch? You are running channels A and B from the receiver outside, correct? All 4 wires? And what happens to the wiring inside the house, or are these the only 2 speaker pairs with the receiver?
