Lizarazu Unregistered guest | Hawk, Appreciate your comment on the following... - B&W ASW675 - REL Q150E MkII Which one is better? I intend to use it to listen to music and for home theater. My current system Yamaha RXV2400 B&W 603 S3 Quad 11L (for surround) |
Silver Member Username: HawkHighlands Ranch, CO USA Post Number: 525 Registered: Dec-03 | Liz: Either are very, very good. I was not very impressed with B+W subs until the current generation came out, such as the ASW675, which is a sub worthy of the B+W name. The REL is among the very best out there, IMO. I don't think you can go wrong with either one, so take the one with the best price. Nice system, BTW. |
Lizarazu Unregistered guest | Hawk Thanks for your feedback. I will go for ASW675 then. What is your opinion on the cable. I am thinking of the Supra Y Link cable. The shop recommended Atlas 3.0 cable instead. Any idea? |
Silver Member Username: HawkHighlands Ranch, CO USA Post Number: 533 Registered: Dec-03 | Lizarazu: I am in the "copper is copper" camp. I just don't see spending big bucks on a sub cable. I suggest yopu go to www.partsexpress.com and look for the Dayton Audio sub cables. About 1/4 the price of Monster Cable, but it is every bit as good. Highly recommended. |
