10 speakers
Username: Alienmotors
Fl Us
i have 10 speakers made by 5 different makes,
and i wanted to know if it was ok to hook up more than 2 in a 2 channal system
Fl Us
it is a dumb ques., but im a newbie to this site and the sound system world, so i could use any kind of help,
thanx
how were you planning to hook up the extra two speakers, and what are you looking for?
Fl Us
i have 10 speakers, and 2 are hooked up right now. and i was just going to feed extra wire from one speaker to another
Yeah uhh don't do that.
Why do you want to add speakers though?
Fl Us
i also just have a aiwa speaker system from walmart lol, with the stock speakers hooked up
Fl Us
i want to add speakers for more sound, and if i do that what will it do?
I wouldn't really suggest hooking anything else up to that...
Fl Us
than should i just get a amp, and a sub with a new system?
"i want to add speakers for more sound"
That isn't the way to do it. What kind of stereo do you have (just the aiwa?), and what are the extra sets of speakers?
"and if i do that what will it do"
Potentially fry it all.
Fl Us
Post Number: 7
than should i just get a whole new system with an amp, and a sub?
"than should i just get a amp, and a sub with a new system?"
Probably. A good Harman Kardon stereo amp and a pair of Klipsch speakers would probably rock your world.
Fl Us
Post Number: 8
sorry i posted twice, and the exra speakers are 2 pioneer ts-6905, 2 sansui 6 in speakers, 2 pyramid 2022sx .
I'm not real familiar with any of them, but minor detail.
Fl Us
Post Number: 9
im sorry for the dumb newbie ques., but ilearned from it so thanx for the info.
Fl Us
Post Number: 10
were can i find the stereo you just named
no problem.
Check www.jr.com; if it is out of your price range check out their Onkyo stereo receivers too. The HK's start around 220 and I think the Onkyos are like 100.
Fl Us
Post Number: 11
http://www.jr.com/JRProductPage.process?Product=3960817
this one right?
yeah,i need to put some money away , cause when i see some thing nice i buy it if i got the money.
and is this one of the best for the money?
thanx
Yeah, there is another for $220 that is 80wpc. But HK is arguably the best you'll find in that price bracket.
Fl Us
Post Number: 12
http://www.jr.com/JRProductPage.process?Product=10643
im gonna get this one cause like i said im not the best with money so this is the one, and 100 watts per channel, not bad right?
I would look at this one instead.
http://www.jr.com/JRProductPage.process?Product=3964198
While Onkyo is a respectable brand, HK is generally better in terms of quality and delivering its rated power.
Anyways, goodnight and good luck, I'm off to bed for the night.
Fl Us
Post Number: 13
ok, i'll see. i'll look around untill cristmas, i forgot it was that time of year lol
thanx
