Problem connecting subwoofer to receiver
Username: Jeze
Post Number: 49
I just purchased a new receiver for my speaker system because my old one burned out. Anyway, the back of the receiver has an RCA output for the subwoofer while my old receiver used the pair of wires.
How can I connect this woofer to my new receiver because really don't want to buy a new sub and I know that there is a way.
Username: Jeze
Post Number: 50
No ideas? Please, i'm pretty desperate @ the moment.
Username: John_s
Columbus, Ohio US
Post Number: 510
Why can't you hook your speakers up the same way as the old receiver?
Username: Jeze
Post Number: 51
The new receiver accepts an RCA connection as the output to the sub.
The old receiver accepted the twisted pair of wires. basically the same way that you plug the regular surround into most receivers.
Username: Nuck
Parkhill, Ontario Canada
Post Number: 342
Your new receiver needs a name, what make and model?
The receiver is giving you a sub out for another amp, inside the sub or out.
Does your sub(make, model) have satellite(speaker) outs?
Username: Kano
Post Number: 747
And what kind of sub is it? If it's a good sub it may be worth the added expense of a power amp to power the sub, otherwise you're better off buying a powered sub.
btlt4
Can we just hook the sub woofer's either L or R+/- channel to unused main speaker ouput posts L or R+/- of the receiver?
